Все о прошивке Nokia N97 mini » Страница 65
Nuts888
#641
У меня она не хочет ставиться... подскажите?
добавлено в 11.39: JAF version 1.98.66 beta5
Detected PKEY: 90009B6C
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-555\
Checking path: \Products\RM-555\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-555\RM-555_12.0.110_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-555\RM-555_12.0.110_prd.rofs2.V27
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-555\RM-555_12.0.110_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-555\RM555_12.0.110_uda_7_001.uda.fpsx
Languages in ppm: English,Euro C ALS
Detected P-KEY: 90009B6C
PRESS POWER ON NOW!
Sending RAW loader...
Using 009.012.005
Elf2flash 09.24.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...........Phone prepared OK!
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 580, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-555\RM-555_12.0.110_prd.core.C00...
Erasing cmt zone 00D60000 - 0D39FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-555\RM-555_12.0.110_prd.rofs2.V27...
Erasing cmt zone 01B40000 - 0D29FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-555\RM555_12.0.110_uda_7_001.uda.fpsx...
Erasing cmt zone 0D3A0000 - 1EF7FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS+CORE
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Done!
PRESS POWER ON NOW!
Using 009.012.005
Elf2flash 09.24.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
germanchuk
#642
JAF и драйверы телефона из архива установлены на ПК. Файлы прошивки из архива находятся в C:/Program Files/Nokia/Phoenix/Products/RM-555.
Я все поставил на комп а эту директорию не могу найти!!! что делать? Подскажите пожалуйста!!!!
Konstantinchik2006
#643
нужно самому создать эту директорию. т.е. создать этот путь созданием папок
acelectric
#644
Angel-iz-Ada, я шил джэтагом с понижением, даже 5800, а ты утверждаешь что не понижается, это любым боксом можно сделать
diesel66666
#645
Ответе пожалуйста можно как то запустить видео в контакте на этом устройстве или нет.Flash Player можно как то заставить грузить или уже все 9.4 пролете
kavkazus
#646
выйдет ли новая прош вообще официальная
SoJloMoN
#647
Будет ли обновление ПО?
MoVeMix
#648
у меня вопрос, после перезагрузки телефона вот такая шляпа вылезла, тел больше не включается
docK2006
Samsung Galaxy Note 4
Ukraine, Kiev
#649
Добрый вечер. Ребята, подскажите пожалуйста, можно ли шиться модифицированной прошивкой Фениксом? N97 mini 30 проша. Если можно, в личку. Заранее благодарен за ответ.
veres
#650
мод прошивки для nokia n97mini
