Дошел сам. может кому-нибудь поможет. нужно выбрать из всего архива файлы со своим продукт кодом. вот список файлов, которые нужны для прошивки (с моим продукт кодом) - RM356_0573745_50.0.005_001_signature.bin RM356_0573745_50.0.005_001.vpl RM356_0573745_50.0.005_001.dcp RM-356_50.0.005_prd.rofs2.V05 RM-356_50.0.005_prd.core.C00 RM-356_50.0.005_C03_prd.rofs3.fpsx RM-356_50.0.005_026_000_U01.uda.fpsx
JAF version 1.98.62 Detected PKEY: 90009699 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:Program FilesNokiaPhoenixProductsRM-356
Searching for default location of ini... Checking path: ProductsRM-356 Searching for JAF saved location of ini... Checking path: C:Program FilesNokiaPhoenixProductsRM-356 Scanning ini files... Searching for default location of ini... Checking path: ProductsRM-356 Checking path: C:Program FilesNokiaPhoenixProductsRM-356 FILES SET FOR FLASHING: MCU Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_prd.core.C00 PPM Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_prd.rofs2.V01 CNT Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_C01_prd.rofs3.fpsx APE Variant file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_026_000_U01.uda.fpsx Backing up CRT... Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Changing flashing settings... Searching for default location of ini... Checking path: ProductsRM-356 Checking path: C:Program FilesNokiaPhoenixProductsRM-356 FILES SET FOR FLASHING: MCU Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_prd.core.C00 PPM Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_prd.rofs2.V05 CNT Flash file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_C02_prd.rofs3.fpsx APE Variant file: C:Program FilesNokiaPhoenixProductsRM-356RM-356_50.0.005_026_000_U01.uda.fpsx Languages in ppm: English, German, Russian, Ukrainian, Bulgarian, Hungarian, Romanian Backing up CRT... Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! вот что джаф выдает( какая проблема может быть
