Прошивал 6720 в нормальном режиме на последнюю версию прошивки плюс делал взлом Лог:
Flashing started Creating product data items list Product data items list created Backup not required Started product mode change Product mode change complete Flashing phone Initializing Asic CMT: Verifying communication to device... Scanning image files... Loading secondary boot code: 14912 bytes Secondary boot loaded Loading update server code: 520994 bytes Update server loaded Partitioning.... Partitioning complete Erasing.... Erasing complete Asic CMT: Start programming 147844 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 40% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 90% Programming complete ERROR: Programming error reported for asic CMT -- Error Type 0x06 -- Error Specifier 0x0E -- Offending Addr 0x534F532A -- Expected content 0x00000000 -- Detected content 0x00000000 Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 Waiting for communication response: 17 Waiting for communication response: 16 Waiting for communication response: 15 Waiting for communication response: 14 Waiting for communication response: 13 Waiting for communication response: 12 Waiting for communication response: 11 Waiting for communication response: 10 Waiting for communication response: 9 Waiting for communication response: 8 Waiting for communication response: 7 Waiting for communication response: 6 Waiting for communication response: 5 Waiting for communication response: 4 Waiting for communication response: 3 Waiting for communication response: 2 Waiting for communication response: 1 Error 0x8401F121 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing И после этого в окошке:The flashing failed. Do you like to retry the flashing? HRESULT 0x84210027 (-2078212057) Firmware updating failed. Error 0x8401F153 - Flash: Unable to communicate with the device after flashing. Check USB connections!
Потом я сам вручную включил смарт и все работает но почему выдал ошибку?
подскажите пожалуйста куда бросить файл RM596_029_000_M013_16G.fpsx,а то я бросил его в папку Phoenix и когда нажимаю Flashing -> Firmware Update то не чего не определяется.
Привет всем!Вот сегодня прошивал свой 6720с, вот такой был процесс, это он прошился или нет?Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Asic CMT: Verifying communication to device... Getting product info... Scanning image files... Loading secondary boot code: 15104 bytes Secondary boot loaded Loading update server code: 381408 bytes Update server loaded Partitioning.... Partitioning complete Erasing.... Erasing complete Asic CMT: Start programming 147768 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 5% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 15% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 25% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 35% Asic CMT: Programming data sent: 40% Asic CMT: Programming data sent: 45% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 55% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 65% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 75% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 85% Asic CMT: Programming data sent: 90% Asic CMT: Programming data sent: 95% Programming complete ERROR: Programming error reported for asic CMT -- Error Type 0x06 -- Error Specifier 0x0E -- Offending Addr 0x534F532A -- Expected content 0x00000000 -- Detected content 0x00000000 Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 Waiting for communication response: 17 Waiting for communication response: 16 Waiting for communication response: 15 Waiting for communication response: 14 Waiting for communication response: 13 Waiting for communication response: 12 Waiting for communication response: 11 Waiting for communication response: 10 Waiting for communication response: 9 Waiting for communication response: 8 Waiting for communication response: 7 Waiting for communication response: 6 Waiting for communication response: 5 Waiting for communication response: 4 Waiting for communication response: 3 Waiting for communication response: 2 Waiting for communication response: 1 Error 0x84009427 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing Getting BB5 Phone Information from Update Server... Unable to get PHONE_INFO for Algos. 0x84009427 Unable to get phone info from update server 0x84009427 Unable to get phone information from Update Server All operations completed Product flashing failed.
braa, да вроде как прошили. Проверьте версию прошивки, отображаемую при вводе кода *#0000#. Чуть выше, кстати, парниша такую же ошибку при прошивке 6270 получил. Можете у него в личке спросить, как вылечил)))
