- J.A.F. (Just Another Flasher) » Страница 410
JAF version 1.98.66 beta5
Detected PKEY: 90007BF6
USB Cable Driver version: 7.1.78.0
Changing mode...Done!
Для прошивки выбраны следующие файлы:
MCU: NONE
PPM: NONE
CNT: NONE
APE: NONE
Checking path: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\
Checking path: \Products\RM-504\
Scanning ini files...
MCU: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00
PPM: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05
CNT: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_C03_prd.rofs3.fpsx
APE: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx
Detected P-KEY: 90007BF6
PRESS POWER ON NOW!
Sending RAW loader...
Using Z+oФ012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
Stage 2 starting..........PUBKEYS already sent...
.......Phone prepared OK!
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 598, APE blocks: 0
Erasing cmt...
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.core.C00...
Partition result: 0014
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_prd.rofs2.V05...
Erasing cmt zone 07360000 - 0935FFFF ... Erase result: 0000
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_40.0.003_C03_prd.rofs3.fpsx...
Erasing cmt zone 09360000 - 09E5FFFF ... Erase result: 0000
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-504\RM-504_32.0.007_001_000_U002.uda.fpsx...
Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS+CORE
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
Phone not found...
Done!
помогите вот лог! а при включении заставка и все!
DjALEGATOR, у тебя телефон не входит в тест режим, после Pooling phone... должен быть test mode, Phone not found...
Second try...
Phone not found... А это означает телефон не найден, вторая попытка, телефон не найден, шей от материнки напрямую, должно получится, также проверь чтоб софта от нокиа на компе не было, если есть удали, также смотри чтоб все 4 лампочки горели зеленым
а так все делаешь правильно
добавлено в 02.20: WB2, версию прошивки не понижал?Прошивал в dead mode?
P.s. Опиши суть проблемы:как прошивал?Было б лучше если б был лог из джафа
- 409
- 410
- 411
- 419
- 420
