тат подскажите почему не могу прошить делаю всё как написано в инструкции написано продукт код не могу выбираю свой и программа выдает ошибку и закрывается ------------- добавлено в 09.08: а если файлы выбираеш ручками пишет вот так такatching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader.......................Loader Sent! Stag
e 2 starting............... и так стоит не чего не происходит
JAF version 1.98.62 Detected PKEY: 9000AAC9 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.34.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for phone...Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Not found!!! Searching for JAF saved location of ini... Checking path: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\
Searching for default location of ini... Checking path: \Products\RM-356\ Searching for JAF saved location of ini... Checking path: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-356\ Checking path: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.core.C00 PPM Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_prd.rofs2.V01 CNT Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_51.0.006_026_000_U01.uda.fpsx Languages in ppm: English, Finnish, Swedish, Norway, Islandic, Danish Backing up CRT... Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Reading IMEI... C:\Program Files (x86)\ODEON\JAF\ProgData\356910033332651_CRT_backup_11181311.pm Done! Backup CRT OK! Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Searching for phone...Found Reading SW version...ICPR72_10w21.3 51.0.006 Reading battery value...3981 mV Init usb flashing... Reading flashid... CMT: 004000EC SAMSUNG (SEC) -> KAT00F00RA APE: 00000000 Flash -> not detected, some times it is normal Verifing ADL communication... Status byte 7 Rebooting to flash mode... Waiting for the phone to reboot... Searching for phone... Sending RAW loader... Using 009.012.005 Elf2flash 09.11.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ....................Loader Sent! Stage 2 starting.................
а 5230 в нормальном режиме шьётся или тоже только в мёртвом ------------- добавлено в 16.09: подскажи пож 5530 в нормальном режиме шьётся или тоже только в мёртвом заранее спасибо
