Все о прошивке Nokia 5800 » Страница 497
MarioN73
мирный
#4961
помогите плиз, выключил смарт и он больше не включается, вибрирует кратковременно, а экран не загорается...
при прошивке выдает это
MCU Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_prd.core.C00
PPM Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_prd.rofs2.V05
CNT Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.001_026_000_U01.uda.fpsx
Languages in ppm: English,German,Hungarian,Ukrainian,Russian,Romanian,Bulgarian
Detected P-KEY: 90007BF6
PRESS POWER ON NOW!
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...........Phone prepared OK!
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 666, APE blocks: 0
Erasing cmt...
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_prd.core.C00...
Partition result: 0014
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_prd.rofs2.V05...
Erasing cmt zone 07180000 - 0915FFFF ... Erase result: 0000
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.003_C01_prd.rofs3.fpsx...
Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-356\RM-356_60.0.001_026_000_U01.uda.fpsx...
Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS+CORE
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
Phone not found...
Done!
при появлении надписи Pooling phone... смарт тухнет 3-4 раза и вырубается...
GoBlinTsht
Xiaomi Redmi 3S
Россия, Новосибирск
#4962
IgorNokia5800,
А сертификат делали? Если да - то когда?
Если сертификата нет - то без вариантов взлом, потому как выдачу сертификатов Nokia уже с год как прикрыла.
добавлено в 21.50: MarioN73,
Навскидку - версия JAF-a не для Вашей ОС-и (Виста или 7 поди, да еще и 64 разрядная...)
И в блоке Writing смущает Write result 27: 1701
Как мне помнится - вместо 1701 должно быть 2700.
Возможно - неверно выставлены галки в JAF - либо тело не в Dead-режиме
master pro
#4963
а моды выкладывают на этом сайти
Rysi4
Nokia 7.1
Архангельск
Возраст - 45
#4964
Выкладывают.
MopeD04
#4965
посоветуйте норм прошу 60,0,003 5800. зарание спасибо)
SuperZANAC
#4966
где взять плеер с рабочим пунктом "добавить из папки" или фикс какой? Голая 60 прошивка.
Нашел очень интересную папку - 102818E7 - с настройками голосового управления встроенными программами( Bluetooth, Realplayer и тд)
M_A_G
Xiaomi Redmi note 8T
Пермский край
#4967
Плейер можно обновить в обновлении по телефона
SuperZANAC
#4968
M_A_G,
пардон, тут просто обсуждние прошивок...
Coolerphp
#4969
Привет Димоновцам! У меня такая проблема, принесли 5800 rm-356, он вобще не включался, прошил его фениксом на 60.0.03. Во время прошивки на дисплее писало 60.0.03 local mode NOKIA. Прошивка прошла успешно, но при включении один раз вибрирует и всё, экран вообще не загорается. У меня есть подозрение что на нём пытались понизить прошивку, или случайно начали шитьт прошивкой ниже чем была изначально. Вопрос такой: как поднять тело, и можно ли понизить прошивку через тестовую, как на н8? Программатора нет, можно ли в домашних условиях его оживить? Может его ещё раз Джафом прошить?
Заранее спасибо!
amurec
Samsung Galaxy S24 Ultra
Амурск
Возраст - 45
#4970
Coolerphp,
Понизить через тестовую нельзя , так как ее нет , можно прошить еще раз , может быть так , что полетели внутренние сертификаты , может быть , что железная поломка .
